[solved] Join two separate paths
seans_potato_biz
Is it possible to join the end nodes of two separate paths together, forming one single path?
Win 7/10, Inkscape 0.92.2
Re: Join two separate paths
Before you can join the paths of two seperate objects you need to make them one object by doing performing a Union first. You can then join the end nodes by selecting them with
and clicking the appropriate button from the Tools Control Bar.
and clicking the appropriate button from the Tools Control Bar.-
Simarilius
combine works as well as union for this.
seans_potato_biz
I found that union turned the two paths into closed loops, whereas union left the loops open for me to perform the operation I intended (maybe there was a way to re-open the loops afterwards. The Inkscape truly is an amazing thing!
seans_potato_biz wrote:I found that union turned the two paths into closed loops, whereasunion[combine] left the loops open for me to perform the operation I intended
Just correcting your statement. Thanks for clarifying the behaviour - I didn't know this.
seans_potato_biz
Thanks (for the correction), no problem and thanks again (for the reply)!
