Hi
In the past I have created a colour palette in Gimp and moved it across without any problem. However, I needed to edit the palette and save as a separate name. My problem is that whenever I have saved the palette it is not showing up in the available palettes. I have checked the location etc but having spent a good 4 hours I am stumped
Hope someone can help
New Palette
Re: New Palette
Did you restart Inkscape? You need to close all Inkscape windows.
Where did you save the palette? It should be in your user config directory, in the subdirectory 'palettes'.
Is the file format exactly the same as for the palettes that come with Inkscape?
Re: New Palette
Hi
Thanks for the reply. I put the palette in inkscape/shared/palettes
With regard to the names I have tried to create a totally new palette and I have tried to alter an installed palette while only changing the colour codes. The later has meant the removal from the list of available palettes.
I have tried restarting inkscape and the computer to no avail. Might try a reinstall if all else fails
The palette I created was copied into the Gimp and is available so I can't understand the problem. Any ideas welcome
Re: New Palette
I'd suggest you rather put the palette into the user configuration directory, into the subdirectory 'palettes'. Else it will be wiped out on Inkscape update.
(See: Edit -> Preferences -> System: user config)
I think that maybe something with your palette file format is wrong, if editing removes it from the list. Things that you could check are the encoding and the line break format.
You can also post one of the problematic palette files to get more help.
Re: New Palette
Will try. So grateful for the reply
Alan
Alan
Re: New Palette
Hi
Just tried the config with a restart with no avail. The following is copied and pasted from my directories and would appreciate a look over
C:\Users\ASUS\AppData\Roaming\inkscape\palettes
Pastel.gpl
Gimp Palette
3 118 163 A
211 85 86 B
160 6 56 C
75 41 68 D
123 45 93 E
219 175 188 F
115 147 208 G
204 186 120 H
130 101 57 I
135 31 54 J
199 94 75 K
225 160 130 L
246 243 164 M
249 224 46 N
238 175 10 O
172 103 34 P
125 135 48 Q
185 193 82 R
168 209 195 S
72 144 141 T
50 119 124 U
26 98 84 V
21 149 98 W
179 207 70 X
54 64 149 Y
78 172 224 Z
244 209 203 ONE
255 255 0 TWO
0 0 255 THREE
178 202 240 FOUR
0 255 255 FIV
E
0 255 0 SIX
157 184 179 SEVEN
81 93 89 EIGHT
43 44 74 NINE
72 116 141 ZERO
255 0 0 PLUS
200 216 239 SLASH
Pastel.gpl
Gimp Palette
3 118 163 A
211 85 86 B
160 6 56 C
75 41 68 D
123 45 93 E
219 175 188 F
115 147 208 G
204 186 120 H
130 101 57 I
135 31 54 J
199 94 75 K
225 160 130 L
246 243 164 M
249 224 46 N
238 175 10 O
172 103 34 P
125 135 48 Q
185 193 82 R
168 209 195 S
72 144 141 T
50 119 124 U
26 98 84 V
21 149 98 W
179 207 70 X
54 64 149 Y
78 172 224 Z
244 209 203 ONE
255 255 0 TWO
0 0 255 THREE
178 202 240 FOUR
0 255 255 FIV
E
0 255 0 SIX
157 184 179 SEVEN
81 93 89 EIGHT
43 44 74 NINE
72 116 141 ZERO
255 0 0 PLUS
200 216 239 SLASH
Re: New Palette
Well, this is one of those "no way!" moments...
Change "Gimp" for "GIMP".
That worked for me.
That worked for me.
Re: New Palette
Yep. Also fixing the linebreak will be helpful (at 'FIV' - 'E')
Re: New Palette
(Is it valid in Gimp without the capitalization?)
Re: New Palette
Moini wrote:(Is it valid in Gimp without the capitalization?)
Apparently not, at least 2.8.16 will not import the palette unless you change it to "GIMP".
Re: New Palette
Thanks for testing, @Uktrunie! So it's not an Inkscape issue, but just a problem with the file not being well-formatted.
Hope it works for you now, @arachnic!
Re: New Palette
Made the changes you both suggested and problem solved. Many thanks for your time and effort. Greatly appreciated
Alan
Alan
