Hi everyone
I have seen that other users have had similar problems.
When I save my file to pdf, the pattern (created by me) appears as with rectangular cells as it appears in attachments.
Why does this happen?
Joaquín
The svg file is very heavy, attached link:
https://drive.google.com/a/alumnos.usm. ... sp=sharing
Problems in pattern pdf file
- dibujo.pdf
- (38.85 KiB) Downloaded 148 times
Re: Problems in pattern pdf file
Google asks me to log in - can you make the file available to everyone?
Ready, now yes
It seems pattern 81373 is composed of 200+ paths. If the paths are combined into one path and converted into a new pattern, that pattern should work better in a pdf.
e.g. :
select object with pattern 81373.
Menu: Object>Pattern>Pattern to object.
Menu: Path>Combine.
Menu: Object>Pattern>Object to pattern.
Use new pattern for fill.
e.g. :
Menu: Path>Combine.
