Good day,
I want to open a pdf in Inkscape, but the text imports as rubbish. Viewing .pdf-file in Evince is correct.
What happens?
Ubuntu 12.04
Thanks an greetings, kl
pdf rubbish text
Re: pdf rubbish text
Hi kl,
There's a small dialog window that appears when you import. Usually it will ask how to handle text. And usually the choices are text as text and text as paths. Whichever one you used the first time, try the other. Although to be honest, sometimes it only gives you one choice (text as text).
I know there's something about flowed text, that's a problem when you're making a document with Inkscape that's destined for the web (if I understand correctly). I don't know if it affects imports (like for example, if the PDF was made with flowed text).
Was the PDF originally made with Inkscape? Or otherwise, do you know anything about its origins?
I'm not sure what else to say..... I guess if you could provide the PDF, we could try the import. Well, I could try the import on my system. But others here might be able to spot the problem.
Sorry, I wish I could be more helpful
The only available option is 'Text as text'. Importing text as paths from a PDF file is not supported so far (yes, it's among the well-known feature requests, but not implemented).brynn wrote:There's a small dialog window that appears when you import. Usually it will ask how to handle text. And usually the choices are text as text and text as paths. Whichever one you used the first time, try the other. Although to be honest, sometimes it only gives you one choice (text as text).
Could be a problem with the text encoding which might not be handled properly by Inkscape's poppler-based import, or protected text content. You might consider sharing the PDF file to allow others to take a closer look.kleinempfaenger wrote:What happens?
I think I may know what he is referring to. If you import .pdf, it works brilliantly, but if you then want to edit the text of the imported file, you'll find out that it is a bit problematic. The pdf import will create one Text element with a number of Spans and all the text inside is "manually" kerned to make up for Inkscapes rather primitive capabilities in this regard. As a result, if you change a text, you newly typed text will NOT get to be where you'd expect, but at the position as defined by the dx dy of the kerning. Ehm,.. if you know SVG you'll get the point and otherwise just import some pdf text and edit it for fun.
There is however a fairly easy way to solve the problem. Use the Split text tool from the extensions with a line setting and apply it on the text you want to edit. It will automatically straighten all the text out and remove the kerning positioning. After that you can easily edit all the text. Unfortunately a tool to put split text back into a single Text with Span has not been created yet (though it happens in the pdf converter, so I guess code could be found there).
If your PDF is protected, just open it with LibreOffice Draw and save it as pdf again (or SVG
. LibreOffice Draw ignores the protection and turns it into usable content. It also creates nice SVG font libraries, for those interested, when exporting text to SVG.
This seems a persistent problem over different pdf's. Inkscape 0.48
The text imported is in single line chunks but the kerning is wrong. The characters are too close together. If I try to edit the text, using the text tool, the new characters are placed on top of one another.
I can change the font but the bad kerning remains. Some lines of text seem to be properly rendered.
Further investigation reveals that if I select Text/Remove Manual Kerning the text expands in length and the kerning is correct but now the line is too long to fit on the page so I have to reduce the font size. Then I find there is some text missing off the end.
I have had this problem with pdf's from completely different sources.
