If I copy some text in to inkscape from an email it seems to treat that portion of text as a group of objects with each line of text a seperate object.
Is it possible to copy and paste a paragraph of text and for Inkscape to treat it as one single object?
Thank you
Martin
working with cut n' paste text from another app
Re: working with cut n' paste text from another app
This is the default behavior, you should get one text object. Are you sure you haven't converted the text object into paths? When you select the object what does the statusbar say?
Try pasting it into notepad or a text application and then copying it from that program into inkscape. Email text seems to have some quirks.
Pasting into notepad first did the trick.
Many thanks
Martin
Many thanks
Martin
I'm curious, what email application did you try to copy from?
prkos wrote:I'm curious, what email application did you try to copy from?
Outllook
Martin
