Is there any way to change the behaviour of the Save As-Dialog in 0.47?
The way it works at the moment is annoying.
- It doesn't write file extension if not manually added
- It doesn't display the name of the actual file in the file name field. One has to retype it or select an existing (older) file in the folder to get the name.
Save-Dialog in 0.46 was much better. Why was it changed?
If possible, I would change back to 0.46, but I need some of the new features of 0.47 regularly.
Does someone have any tipps?
