cheers
brynn wrote:When I've watched sewing shows on tv, they often put some kind of backing behind the place where the machine is going to work. I don't remember why they did that. But I assume to help with feeding the fabric under the needle. Or possibly to help keep the design flat through washing and wearing, too?
In german because i dont know the correct english words:
Klebt ihr da einlage von hinten drauf um die stickerei zu stabilisieren ?
Ansonsten ist t-shirt jersey nicht so das optimalste material weil es sich stark verzieht.
Wow, the result on fabric is so much different from the image!
Does the embroidery machine do all the work? Or do you have to guide the fabric with your hands? I would think the computer guidance would be much better than that.
OR.....could it be the quality of the fabric? Perhaps a much stiffer fabric is needed? I only know the words from old fashioned sewing machines. But it looks like the feed dog was slipping. The feed dog "feeds" the fabric under the needle. There should be settings to help control that, according to the thickness and/or stiffness of the fabric. Although this only comes from my knowledge of old home sewing machines, not industrial machines. But I do remember how hard it was to sew with satin fabric, because it's so slippery -- the feed dogs have a hard time grabbing it, and the stitch tension needs to be just right.
Is this a home machine which can do embroidery, or is it a dedicated embroidery machine, and that's all it does?
Yes, there are some hints about this in Alexander Brock's raumzeitlabor wiki posts: https://wiki.raumzeitlabor.de
