I remember that you used to be able to press Shift + L while drawing to change the segment you're placing from a curve to a straight line. But it's not working for me now. Is this something that changed in an update? What did the shortcut change to?
The manual still lists the shortcut that does not currently work: http://tavmjong.free.fr/INKSCAPE/MANUAL ... ths-Bezier
Thanks!
Shift + L for straight line after Bezier curve not working
chuckmcknight
Re: Shift + L for straight line after Bezier curve not working
I just tried this with Inkscape 0.91 - and there it works inconsistently.
Then I tried with Inkscape 0.92.3, and there it works reliably. Which version have you been using?
chuckmcknight
Just checked, and it's 0.91. For some reason I was thinking that Inkscape notifies of available updates, but I guess not. I'll update and try again. Thanks!
chuckmcknight
That update seems to have done it! Thanks again!
You can subscribe to the inkscape-announce mailing list to be notified of new versions (or to the user mailing list to get some more info, it's low volume), or follow Inkscape on twitter/g+/facebook/mastodon.
http://inkscape.org/en/community/mailing-lists/
