Hi, there is a plugin for plotting in Inkscape?
Thanks in advance
Plotting with Inkscape
Re: Plotting with Inkscape
There are many of those. One of those is even integrated into Inkscape (Export -> Plot...).
There are extensions for function plotter and parametric curves.
If you have a simple dataset:
http://www.inkscapeforum.com/viewtopic.php?t=16328#p60200If your data are (ordered) x,y couples you just have to write
<svg>
<path style="fill:none;stroke:#000000;" d="M %yourdata%" />
</svg>
in a text file named foo.svg and voila (minus the scaling but you can do it in inkscape)
