Something tells me I should know how to do this, but I can't come up with it. I know that one cannot make a gradient follow a path, at least not without some distortion. But there must be some way to make this work. Here's a screen shot of what I'm trying to do.
The image is my avatar for this website, and I want to try animating it, so that it looks like a fill is in the process of being painted, like with a paint brush.
I know that for an animation, I need to create a series of "snapshots", of the pink dot with its gradient "tail" as it moves along the knot. But I can't figure out how to make it turn the corner. When I get to a corner, the fully opaque, or beginning end of the pink streak will need to be going in a direction 90 degrees, or perpendicular, away from the direction the tail, or fully transparent end of the streak, is going.
Will I need to make the pink streak into a series, of say 4 or 5 pieces, so that I can arrange them as needed to show the streak as it rounds a corner? And actually, there may be places where the streak covers 2 corners (or maybe even 3, for the loops on either end of the knot). I'm not sure how long it will be, in the end.
But my main problem is that I just can't come up with any way to show the pink streak rounding the corners of the knot. Do you all have any ideas about this?
Or am I gonna have to use a raster type program, like The GIMP? Because I know you can make a gradient follow a path, although that's probably not the right terminology. I can't remember how to do it, at the moment, but I'm pretty sure it can be done.
But I really would like to stick with Inkscape, for the "snapshots", and just use GIMP to animate. If possible.
Thanks for your help
