I've just been getting an image ready to post, following the Competition #4 theme of birthdays. At 1st I thought I might actually enter the competition, but I'm not sure I'm good enough to have my work in the Open Clipart Library
So this image has a lot (or what I consider a lot) of both shading and highlights. As far as highlights go, using gradients in some areas, and blurs in others, in this case it's mostly white or slightly off-white. Parts of the gradients and/or blurs fall outside the outline of the image, but since it's basically white on white in these areas, it doesn't show. And until now, I thought that was fine, because it still looks like what I want. But as I think about "finishing" it for "presentation", I realize maybe I, or a potential user of the image, might want to put it on a dark background. But if they did, then little pale blurry blotches and wisps are going to show up where the ends of the highlights fall outside the outline of the image.
So how do professionals finish their work, so it can be used on any background? Mostly I've been thinking they must clip or mask the whole thing, after it's finished, to exclude these areas from the final product. But I'd be interested to hear any comments about this.
As I was cleaning up the canvas of all the bits and pieces where I created various parts of the image, and did a really lot of experimenting, I thought I should do something to kind of "lock" my image together, so it doesn't unintentially "come apart". Because my goodness, there ended up to be 19 layers, some with up to 10 subpaths and others with 10 or 12 gradients. (I'm sure it could be done with less, but I'm still learning.) So I rubberband selected the whole image, and Grouped it. I thought that would keep it from coming apart, and so far it has. But it also crammed everying into one layer, and so far I haven't been able to ungroup it, to edit. I may eventually figure out how to undo this mistake
How do professionals handle this? So far, I haven't come up with any reasonable guesses, so I would really appreciate comments about this.
Is there some way to attach the artist's name to the image? Not exactly like signing a painting, but just part of the file, so that it goes with the image, where ever the image is used? Also, I've noticed that most graphic artists don't sign their work...none that I've noticed, anyway. Why is this?
Also, if anyone wants to share other related gems of computer graphics/graphic artist wisdom, I would be most appreciative
And as always, many thanks for your generous and most excellent help and support
