From left to right:
original concept, permanent markers and wood finish on packaging paper
pencil drawing on plywood
permanent marker on glossy print foil
two rendered images with blender
a composite of the previous two
the raster image traced with inkscape
Original size is 350 mm / 1000 mm, had cut off the header part on the top -two of the photographs taken had them.
Will have to print out the final result, still I'd like to add in some details and end up with a grubgier, more industrial look as on the first image.
Have to figure out how to manage it, since filtering may be a bit processor melting at this scale.
