I've uploaded a short video here that shows what happens when Ctrl is pressed down when moving a node. There is two objects, where the upper one is just a copy of the lower one.
http://youtu.be/GEh6nHetzj0
Is there a bug repport that match this behaviour or should I just make a new one?
Workaround is fairly easy: Just start moving the node by holding down Shift and Ctrl while moving. After moving the node a bit, then release mouse and move the node againg by holding down Ctrl only.
Node tool forcing snap between 2 nodes when Ctrl is down
Re: Node tool forcing snap between 2 nodes when Ctrl is down
This does not happen here, what are your settings for snap in preferences?
Using Inkscape 0.48+devel r12162. Win7 - 64bit.
RGDS
Ragnar
RGDS
Ragnar
Good Luck!
( ͡° ͜ʖ ͡°)
RGDS
Ragnar
( ͡° ͜ʖ ͡°)
RGDS
Ragnar
Snap settings is as follows - see picture of snap bar.
I've also atached the svg file (forgot to do so in first post).
- Beskyttelse2.svg
- svg file
- (16.99 KiB) Downloaded 191 times
- Snap bar (settings)
- snapping_settings.png (2.94 KiB) Viewed 2543 times
Hei.
Got it - might be considered a bug or "undocumented feature".
Av filnavnet - er du norsk?
Hilsen
Ragnar
Hilsen
Ragnar
Good Luck!
( ͡° ͜ʖ ͡°)
RGDS
Ragnar
( ͡° ͜ʖ ͡°)
RGDS
Ragnar
Grobe wrote:Is there a bug repport that match this behaviour or should I just make a new one?
BTW - the bug tracker does have an advanced search option (use e.g. the 'tag' entry with 'snapping' to narrow down the search); and you can even use e.g. Google to search for inkscape bug reports ('site:bugs.launchpad.net/inkscape' limits the results to hits in reports & comments from the bug tracker)
AFAICT Bug #681286 “[snapping] nodes ctrl-drag not always working properly”
(affects development builds only, but not stable versions).
Have tested with stable version of Inkscape and confirm that this behaviour does not apply.
[ot]
[ot]
Nei, kordan i all verden kan du finne på å tru nokka sånt?ragstian wrote:Av filnavnet - er du norsk?
Off topic:
~suv wrote:....and you can even use e.g. Google to search for inkscape bug reports ('site:bugs.launchpad.net/inkscape' limits the results to hits in reports & comments from the bug tracker)
~suv (or anyone), I know you told me how to do that a long time ago. Unfortunately I had lost the message where you explained
Thanks for your kind help
