Hi there,
i am having a rough drawing (Vector) which i need to reconstruct. Therefore i need to create on top of each pathline a new one, which needs to have its waypoints on identical positions like the underlying waypoints of the underlying draft.
Is there a way to arcive such an effect that while i am drawing the new curve, the new waypoints do snap to the existing ones of the draft?
Thanks for helping me out on this
Heiner
[solved] Snap to existing points
Re: Snap to existing points
I don't think there is node-to-node snapping, sorry. You could simply duplicate the draft path though.
Heiner
Doh,
thats too bad. Hmm, but your suggested idea could be a solution, if ...
Let me explain my issue a bit more in detail: I do have a cobination of lines from a 3d programm, which look combined like a half circle. What i need to do is to reconstruct that shape, going trough all the initial refference points and instead of beeing a collection of single lines with corners i need it to be one line with smoothh bending.
Any idea how to archive that?
Heiner
Heiner
You could use "trace bitmap" but I don't think that is what you want. Other than that, the only way I know how is to hand craft it. If the shapes are consistent you could use tiling to make multiple copies of the semi-circles. If they are perfect circles you could use the circle tool and draw an open circle. I think I would have to see the image to give proper advise.
Heiner
Hmmmm,
i could send you a file to look at, if you would take the time. Would be most apprechiated, if you do ...
Heiner
Heiner
Heiner wrote:Hmmmm,
Heiner
Are you open to uploading it onto the web for us all to see?
microUgly wrote:I don't think there is node-to-node snapping, sorry. You could simply duplicate the draft path though.
What am I saying!? Why didn't anyone pull me up on this?
Heiner Hink
Hi Microugly,
sorry for beeing so quiet the last few days, but i only have internet accsess on certain days. Thanks for digging up that answer, ironicaly i found it myself rather by accident. However, thaknks for your kind help.
Heiner
Heiner
