Hello everybody,
I just stated that I can not regulate font sizes below 12 (pt) with the line spacing setting - there is a line spacing, although it is set to zero (font size: 6 (pt)). Does any of you know what I did wrong?
Best Regards,
Augustine
Problem: Adjust line spacing for small font sizes - 12 (pt) and below
augustinus
augustinus
Re: Problem: Adjust line spacing for small font sizes - 12 (pt) and below
BioBrimm wrote:I believe that I found the solution. While I don't understand it fully, this worked for me.
You need to make sure you are adjusting the "Outer Style" of the text when you change the font size. To do this (1) click on the icon next to the font size drop down menu, so that the icon is highlighted;
(2) once the icon is highlighted, re-change the font size to your desired font size. This should fix your spacing for your small font.
It's a bug. Answer above.
Best Regards,
Augustine
