I'm trying to do what this guy does by making the calligraphy tool act like the pencil tool. I can't figure out how to do it in Inkscape
https://youtu.be/DJxMGYXvh0g?list=PL6PkJVw4lxuu_rnD8_hFVFrlnMrPcehxT
Specifically where he does: [stoke path > stroke with a paint tool]
Thanks!
Help using Pencil type for the calligraphy pen.
jimydog000
Re: Help using Pencil type fir the calligraphy pen.
I guess you can't, vector graphics doesn't use "paint tools", but just math to draw.
I think what you're looking for is an LPE, specifically the PowerStroke LPE.
See also: https://www.youtube.com/watch?v=HNoQMqq8xCs
http://wiki.inkscape.org/wiki/index.php ... owerStroke
It appears the author of that video is using GIMP, which is a raster editor. Inkscape's Calligraphy tool is very different from GIMP's. That's because Inkscape is a vector graphics editor.
We still need a good page to explain the difference for newbies. But this is all I have for now: https://en.wikipedia.org/wiki/Vector_graphics
jimydog000
brynn wrote:It appears the author of that video is using GIMP, which is a raster editor. Inkscape's Calligraphy tool is very different from GIMP's. That's because Inkscape is a vector graphics editor.
I know that! -_- ...I can't help but feel slightly offended.
You can pattern along a path in inkscape, so there's no reason why you can't emulate the pencil properties.
Thanks for showing me the powerstroke, but it's not what I want to use right now.
I'll just trace over the paths I have made in Gimp unless someone else has an answer
Re: Help using Pencil type for the calligraphy pen.
You do realize that
has several options, where one of the defaults behave quite similar to the provided example?
has several options, where one of the defaults behave quite similar to the provided example?-
jimydog000
Oops I meant the "draw bezier lines and curves" tool. My bad.
I get what the OP would like for Inkscape to do... I think that would be great.
But it doesn't yet.
PaP is close, Power stroke is close, but neither will apply the options of the calligraphic Pen to an existing path. That would be a very useful tool.
But it doesn't yet.
Indeed, but there is a workaround...
Draw the desired shape with Bezier tool. While still selected, activate the Calligraphy tool and then hold Ctrl in order to have the initial shape as a guide. It is kind of tricky to manage but it is doable.
YES. This is quite close... thanks for that tip!
