1) This is my problem. There are two shapes being clipped (for no apparent reason to me). The larger one behind is a duplicate of the one in front. The blur
is set to 10% on the small one, and about 20% on the second.
1.5) A closer look...
2) As you can see, blurring with only 4% on the smaller shape does not produce this clipping effect.
3) This is the shape with no blur, to show that the shape itself isn't the cause.
4) Outline mode for same reason.
5) Oops, this isn't included - you'll just have to trust me on this one! This was the exported image (ie the png file) - just to show that it renders WITH the clip, it's not just a visual temporary bug that you can usually fix by scrolling around.
Any suggestions?
