I usually like to have the Objects dialog opened, and Layers dialog is a must in my workflow. So both dialogs are iconified sometimes in my lateral panel. What drives me mad is to have the same icon for two different things: Objects and Layers. I need to change the Objects dialog also because it doesn't represent correctly the idea of a stack of objects.
After creating an icon, I suppose I have to place it in /usr/share/inkscape/icons (on Ubuntu, installed thru regular repositories; not by flatpak system). If this is wrong, please point me out the right path.
And how do I name the icon file in order to show it in my interface?
Note: this are the paths to icon themes in my system:
/home/myuser/.local/share/icons
/usr/share/openbox/icons
/home/myuser/.local/share/flatpak/exports/share/icons
/var/lib/flatpak/exports/share/icons
/usr/local/share/icons
/usr/share/icons
/var/lib/snapd/desktop/icons
/usr/share/openbox/pixmaps
/home/myuser/.local/share/flatpak/exports/share/pixmaps
/var/lib/flatpak/exports/share/pixmaps
/usr/local/share/pixmaps
/usr/share/pixmaps
/var/lib/snapd/desktop/pixmaps
/home/myuser/.local/share/inkscape/icons
/usr/share/openbox/inkscape/icons
/home/myuser/.local/share/flatpak/exports/share/inkscape/icons
/var/lib/flatpak/exports/share/inkscape/icons
/usr/local/share/inkscape/icons
/var/lib/snapd/desktop/inkscape/icons
/home/myuser/.config/inkscape/icons
/usr/share/icons
How can I change the Objects… dialog icon so it can be different from Layers' one?
Re: How can I change the Objects… dialog icon so it can be different from Layers' one?
There is not any easy way.
Looks like you have already filed a report, so perhaps all that is left is to make a unique icon.
Yes, copy the icon file /usr/share/inkscape/icons/icons.svg into ~/.config/inkscape/icons , there you can edit it.
(this will only work if the dialog does not use the same icon name internally, which I did not check)
Celita has filed a report indicating the following:
(What I meant earlier, is that all that mere mortals (like myself) can do is make an icon and offer it to the devs to be programmed into Inkscape.)
I had checked the verbs.cpp file and there is a mistake: both verbs for Objects and Layers dialogs have the same icon defined:Code: Select all
new DialogVerb(SP_VERB_DIALOG_OBJECTS, "DialogObjects", N_("Object_s..."), N_("View Objects"),
INKSCAPE_ICON("dialog-layers")),
Yep, I see. It's still wrong in the code. Although, I think you'd be able to fix it. It doesn't require any programming skills to rename that to dialog-objects and to add the corresponding icons into the various sets.
I understand it is not a complicated change: make a dialog-objects icon, add to the set, edit the verb.
I was under the impression the edited verbs.cpp still has to be included in a new build.
Edit: And a new <bind> ( and update to keys, if a shortcut is added). (?)
http://wiki.inkscape.org/wiki/index.php/Adding_interface_verbs
I think the shortcut might have been left out intentionally, for people to select themselves - most shortcuts are already taken, which starts getting problematic. But if you can find one that's still free and somehow fits, then why not.
Yes, if you edit a C++ file, Inkscape needs to be re-built (if I understood correctly what you were meaning, I'm not sure...)
And yes, if you add a keyboard shortcut, this should be documented in the documentation repository, and the various keyboard shortcut files (or at least the default one, not sure how that is usually handled) need to be adjusted.
