I created a draw in QCad Prof 2.2. I save it once in dxf format and twice in the SVG format to be able to open the drawing in Inkscape.
The drawing, in QCad Prof have several layers where I distribute different parts of the drawing.
I load my drawing in Inkscape.
All the drawing is open on the "background" of the file that Inkscape open. No layer is created.
I want to replace parts of my drawing in they own layer. To do that, I create several layers and under-layers.
I select a part of my drawing (100 to 200 little elements) but I can't mothem to a layer via the "Layer" menu. I'm obliged to cut them , activate the layer I want to use and paste them.
That represent no problem in it self but where I have a problem it is the time used to move the part of my drawing to the layer : 20 to 40 min. ! To recreate my drawing whith the different parts in they own layers : 8 hours !
And when Inkscape is cutting and pasting the elements of my drawing, it use 100% of the first CPU and between 30 and 90% of the second CPU, and it use 100 % of the mémory of my computer !
It use "only" between 4 and 12% of the swap memory.
My file is a image SVG (image/svg+xml) and is 4,4 Mio (4633454 octets) big.
It contain +- 15000 objects !
I have had several problems when importing dxf file created by AutoCad and aloso fils from QCad Prof. That's why I generate a SVG file from QCad Prof.
The file is OK but I lose all the layers.
Using XML editor in Inkscape is also very very long and unusable !
1 time on 15, I can Click and drag a element in the list of elements in the XML editor. The other times, the element I try to drag stay in his place in the hieararchy. I only can move it using the arrows but step by step ... and when the objet must be moved 2500 places further ...
My configuration :
I have 2 GiO ram, a swap partition of 2 GiO
Linux is :
Ubuntu 9.10 Karmic
Linux kernel 2.6.31-14-Generic
Gnome 2.28.1
CPU Dual core Genuine Intel CPU 2140 @ 1.60 GiHz.
Is this a bug ?
Do you have a solution ?
Thank's
My first way to get some solution is to brake my drawing in 4 or 5 parts. In this case, it is possible but when it will not be possible ... what can I do ?
I'v tried to create a group with 4200 objets : 4 hours !
But QCad Prof woks fine with so many objets
I have tried with parts of the drawing.
In a SVG file, I have 5092 objects.
I select 2042 objets and make au group.
Inkscape take 24 minits to do that ! That is 1.45 object manipulated/second !
It is not very fast ! I can say a little slowly, isn't it ?
I have an othe proble with the TTF fonts : Inkscape find them, present to me the list of the fonts but it can't use them. It replace them by a font by default. I continue to find if a answer about that trouble exist.
