Read it here.
and hit Tab to cycle through all six faces. The way it's done in the tutorial you need to delete the faces on the bottom and rear left and rear right. In the attached pic I've exploded the cube to expose the hidden faces. You'd want to delete the faces numbered 3, 4, and 6.GAngus wrote:Darn, I get to the point where it says "remove the invisible sides"...
if they are invisible, how can I remove them (silly)
