I intended to publish my SVG graphics as web pages and found that text didn't appear in the browser. Then I dived a little into SVG documentation and learnt fonts must be converted and embeded. (If there was any clue on how to have this done, I didn't get it). Then I read in Batik webpage that a feature concerning this point was included.
So does Inkscape? What's the path to it?
Thanks so much.
embedding fonts for web publishing
Re: embedding fonts for web publishing
Did you use Flowed Text instead of Regular Text? See Inkscape Faq: What about flowed text?.Marcelo wrote:I intended to publish my SVG graphics as web pages and found that text didn't appear in the browser.
Inkscape does not yet support creating and rendering text with embedded SVG fonts [1]. Alternatively - to make sure the text looks precisely the same in all browsers across platforms - you can convert the text to paths (using 'Path > Object to Path'), but this will increase the file size a lot.Marcelo wrote:Then I dived a little into SVG documentation and learnt fonts must be converted and embeded. (If there was any clue on how to have this done, I didn't get it). Then I read in Batik webpage that a feature concerning this point was included.
See also the comments about the current status and roadmap of SVG fonts in "SVG WorkingGroup > SVG Fonts".
[1] Inkscape does have a built-in SVG Font Editor to create such fonts, but it can't use them as font-family for text objects.
Yup, that solved my problem, much easier than I expected. No need to embed specific fonts, at the moment.
Thanks so much again, -suv
I don't know if it's appropriate to revive a question that I seem to be having the same trouble for. I don't want to add "yet another..." of this question when this question works fine. Please tell me a better approach if this wasn't it. Anyway, on to my question.
I dug around on the web for a long time and here as well, and can't find a solution that works for me. I'm making a graphic I want to be able to use on my website in SVG so that I can dynamically change its size with clarity. It has included text in a script/handwriting-type font. It looks great in Inkscape but when loading in my browser, the text uses a default font instead. I tried selecting the text and going to the Text menu > Convert to Text but when I save and reload my graphic, it's still the default font. I understand that SVG and fonts are still iffy in the specs, so was wondering if there's a workaround to this besides outright converting the text to an object?
Thanks for any teaching and information you can provide.
I never have quite understood the difference between Text menu > Unflow and Text menu > Convert to Text. The manual says this:
But I'm not sure what "link-flowed text" is.
I do know that if you use Text menu > Unflow, it will put your text all in 1 long line. This has been a couple of years ago, but I tried Convert to Text, and it didn't make the font show up on a webpage. Unflow made it work, but then it was 1 long line. So I had to go through and "manually" insert Returns (Return key used to be the carriage Return on typewriters, but on computer keyboards is called the Enter key), where I wanted each line to end.
That could become tedious, if there is a lot of text. I saw an extension for hyphenated text, the other day. But I haven't tried it yet. Maybe it only works on flowed text....but maybe chooses and inserts the "returns", I'm not sure. But I'll test, and post what I find out.
Oh, I see, now that I read about it http://thottingal.in/blog/2009/10/03/in ... extension/
It works on text that's justified, and fwict, only flowed text has the option to be justified.
But when I test just now, Convert to text did change the flowed text to regular text. I haven't tested with a webpage, but I'll try that next.
Flowed text can be converted back to a regular text object with the Text → icon Unflow (Shift+Alt+W). The resulting text will be on a single line.
The Text → icon Convert to Text command converts link-flowed text to a regular text object while preserving the appearance of the text. The text is still editable but will no longer reflow inside the shape or path frame. This is necessary for display of the drawing in another SVG renderer.
Btw, did you say which version of Inkscape you're using? There have been many new versions since the last time I tried this. I'll be using 0.91 this time.
Hhmm... Ok, let's see if I can insert SVG image into this message.
Well, I can't see it at all. Added purple blob, to make sure image is there. Text should be some lorem ipsum with a font called Sprint. I thought I'd be able to see it. But apparently this forum can't display flowed text at all.
Actually, I didn't think flowed text could be displayed on the internet at all, now that I think about it. But you seem to indicate that it's being displayed, except with wrong font.
I'll test other forum.... Nope, can't be seen there either.
Now using Convert to Text:
Well, it seems to work here!
Maybe you're having some kind of confusion. Because I didn't think flowed text could be shown on the internet with any kind of viewer. Are you using flowed text at all???
If your issue has nothing to do with flowed text, then the answer is that you either need to embed the font or convert to paths.
I'm using Inkscape Portable version 0.48.4. Sorry for not mentioning that earlier. The text I want is on a path. Is there a way to embed the font and have it work on the pathed text? I'm ok with doing that if I have to.
Font embedding into Inkscape's SVGs doesn't work, but you could add the font file to your website and link to it from the CSS you are using - or even directly from inside the SVG...
Didn't try it, but there should be a way of using CSS and the SVG file and the font files.
Ah - here's an article: http://www.andrejkoelewijn.com/blog/201 ... -inkscape/
(just search for "CSS Inkscape SVG font" with google to find more)
If you embed the font in the code, it will work on any text on that page which has that font name. It doesn't matter whether it's on a path or not.
If you don't want to embed fonts in the code, the only option is to convert the text to path. It doesn't matter whether you convert it to paths before or after you put on path.
