Erasing
Geinartone
Erasing
I'm trying to figure out how to erase something...hard to explain...let's say you make a circle with no fill and an outline only...then you have 3 lines going through the circle, but you don't want the lines showing inside of the circle outline...how would you do that?
Re: Erasing
Not with the Eraser tool.
If I understand what you're asking, here's how I would do it.
1 -- Draw the circle
2 -- Draw a long skinny rectangle, which will be used to create one of the missing lines.
3 -- Duplicate and move it downwards
4 -- Repeat
5 -- Select the circle and the top rectangle
6 -- Path menu > Cut Path
Before you deselect the results, notice on the canvas that there are 4 parts to the circle now. And notice where the 2 pieces are, which will need to be deleted.
7 -- Deselect everything
8 -- Select each piece and delete
9 -- Repeat 5 through 8 until finished
4 -- Repeat
Re: Erasing
Maybe this?
Geinartone
Re: Erasing
Exactly that Tyler! Thanks for the help!
