Hi All,
Whenever I hit the circle/ellipse tool I get what you see in the attachment. Anyway to just get a normal ellipse w/o the color? Thanks
Ellipse is all jacked up
- ellipse.svg
- (1.94 KiB) Downloaded 66 times
Re: Ellipse is all jacked up
Your ellipse looks weird because the stroke is a huge 152 mm causing it to overlap itself on all sides and intersect according to the fill rule which may not make sense to you right now but the short answer is make the stroke a reasonable width and your problems will be solved
