Hi All,
I draw the square 150x150 mm.
how to find the midpoint?every time i show the x,y position.
in croreldraw12 easily find the midpoint of any object.
please suggest me how to this possible.
Square Midpoint Find
Re: Square Midpoint Find
select your square with
click it again with the same
now the scaling arrows at the corners and sides have changed to rotation and shear arrows, and the object center has appeared as a + in the center. Shift click it if you think it has been moved and it will jump back to the center.
now the scaling arrows at the corners and sides have changed to rotation and shear arrows, and the object center has appeared as a + in the center. Shift click it if you think it has been moved and it will jump back to the center.Your mind is what you think it is.
