Using Font Awesome inside Inkscape
Font Awesome 5.9 is now available on their Github repo. I was wondering whether we can have some method to add them to our drawing. I have their fonts added to /home/.fonts folder of 18.04. I am not sure where and how to fetch these icons. Any help will be great, thanks.
Re: Using Font Awesome inside Inkscape
Try these:
https://github.com/Xaviju/inkscape-open-symbols
And if you have installed the font on your system, you can instead also just find it as a font to type out. You may need to use the unicode text entry method to get the correct symbols.
Thanks Moini . I tried open symbols. Sadly, 5.9 is not included.I tried typing into the Text box and then selecting font as Font Awesome inside Inkscape. It is a bit buggy.
Edit :
I tried copy pasting images from the cheat sheet into the blinking text area. Looks it works. Happy for now
Edit :
If you get the desktop version from here:https://fontawesome.com/how-to-use/on-the-desktop/setup/getting-started
you can load SVG from the repository. You might need a quick viewer to find what you need.
Thanks Polygon. Do you mean importing SVG as we do for other images into Inkscape ?
Yes. Both will work: drag&drop SVG onto the Inkscape canvas and import via file menu->Import (cmd+I) on macOS. A third method will be to open the SVG and copy&paste into your existing opened file. Can´t tell for Windows etc though.
I am on Ubuntu 18.04. Thanks for the tips
