New Inkscape user here and I have been confronted to a rather frustrating situation that I have been trying to resolve for hours now without success, so I am turning to you.
When using the bezier tool to generate arrows, the endpoint arrowhead gets placed at the begining of the path instead of the end and at a right angle to the path. Also if I try to put an arrowhead on the Starting node, it also appears on the first node, but appears under the line facing upwards. I do not observe this behavior with the free hand tool (bottom arrow in the picture) even though I drew both the same way. Am I missing something? How can I make sure the arrow points to the right like it should?
Thank you for your help
