Need help with this
Need help with this
Is there anyway i can create such drawing using any tools or extension? Please help asap
Re: Need help with this
You could use the Polar Coordinates arranging. Make a big circle, make 8 smaller circles, select everything (make sure to select the big circle first or last), then select the correct options in the dialog (Object -> Arrange, 2nd tab).
Moini wrote:You could use the Polar Coordinates arranging. Make a big circle, make 8 smaller circles, select everything (make sure to select the big circle first or last), then select the correct options in the dialog (Object -> Arrange, 2nd tab).
I dont really know how to use the polar coordinates arranging...
This will help:
Hold down Shift while clicking on the circles to add them to the selection. You can make the smaller circles larger to get overlapping.
- draw circle
- duplicate (Ctrl+D)
- move it to the right (Ctrl+mouse drag)
- select both (Ctrl+A)
- combine (Ctrl+K)
- duplicate path
- rotate duplicant 90°
- select all
- combine
- duplicate object
- rotate duplicant 45° (Ctrl+dragging handle)
- select all
- combine
- draw another circle
- select all
- center align the two objects (Ctrl+Shift+A)
- combine objects together
Moini wrote:This will help:
Thanks mate it works!
