I've used Pattern Along Path before, without any trouble. But it's been awhile, so maybe I've forgotten something. However, I am following the tavmjong bah Manual....http://tavmjong.free.fr/INKSCAPE/MANUAL ... nAlongPath
Here's a screen shot of what I'm getting, including the dialog settings:
The Manual says
"The bounding box of the pattern is used for placing the pattern along the path, with the bounding box of one pattern copy touching the bounding box of the next copy (if no additional spacing is specified)."
But it appears that the bounding box must have somehow shifted! The star is not whole. I'm guessing it appears this way because the bounding box of the Pattern, and the bounding box of the Path, MUST both begin at the same point. In this image, I did not line up the bounding boxes before applying the Effect. And when I do, the pattern follows the path in "full units" so to speak.
Is this a correct assumption, that the bounding boxes of both the Path and the Pattern must be aligned? If so, I'm curious why Inkscape doesn't automatically start the Pattern wherever the Path starts?
I'm using v 0.46, the last stable release, and looking forwards to v 0.47 (which is due out sometime before too long). Does anyone know how it works in 0.47? I searched Launchpad, but didn't find anything, although I know that sometimes you need to know the magic words to search with. If there's no good reason why Inkscape doesn't automatically align the bounding boxes when the Pattern Along Path Effect is applied, I'm thinking of submitting the idea to Launchpad. Because it's going to be a bother to align them just right. What do you all think?
Thanks for your help
