I drew a lovely curved path using the freehand pencil, then did the text, then put along path. I moved the curved text away from the path so I could delete it, meaning the path. Nothing worked. Then I read somewhere that you can select the path and to remove it you can turn off the stroke fill. I was unable to do this.
Heeelp! Removing Path frm under Text
Hi Everybody
Can anyone explain to me how to do this please guys? Is there a simpler way to remove the path?
Thanks so much. Bye 4 now emma27
Re: Heeelp! Removing Path frm under Text
Yes, one way to remove the path that you have put your text along is to simply remove the stroke. Another way is to make it transparent.
1 - select the path
2 - open Fill and Stroke dialog and click the Stroke Paint tab
3 - either click the X to remove the stroke, OR move the A slider all the way to the left to make it transparent
1 - select the path
Hi brynn
Thanks so much for your prompt help. I'll try this today. emma27
