Is it possible to put pictures on path ? Like i do with text?
<textPath xlink:href="#aplis3">
I know it`s not a Inkscape related question but i can`t find any usable SVG forum.
picture on path
Re: picture on path
You mean so the picture distorts to the shape of the path? The answer to that is 'no'.
ivan louette
Re: picture on path
If you mean like what is called "inline graphic" in other packages (QuarkXPress, Freehand...) that would be interesting ! In Freehand for example you can copy or cut any graphic and paste it at a letter emplacement inside a text line, even if thes text follows a path. Afterwards you can apply to it what function you would apply to text (italic, move from the baseline, kerning...)
If anybody knows the svg code to introduce it Inkscape that could be very useful !
ivan
ivan
Re: picture on path
You can do this with Inkscape. You just can't do it using raw SVG.
