FHMC exercise in paths
To complete this tutorial I need to place the Fuji mountain top over the text. But, I am unable to move it correctly: the white top keeps going under the letters. So, I move it up, without results. Then I do a "move down" with the letters; again the snow goes under the letters. This last move ought to be simple but it doesn't work. Now I know that I miss a step; what could it be?
Re: FHMC exercise in paths
Please attach your file to a reply, so we can examine it and better help you.
Am attaching the requested file.
- FHMC.svg
- (6.24 KiB) Downloaded 292 times
"Your message contains too few characters." What is meant by this?
Requested file has been attached.
The message is probably from having no text written in the message. Not a problem at this point.
Some issues:
The image in your file is "linked" to a location on your computer. The linked image would usually need to be uploaded with the svg file or embedded in the file. Also not a problem at this point (for me), since I have replaced the image with a downloaded version.
There does not seem to be a "snow peak" trace in the file, so I can't recommend a solution other than to trace the mountain top again and give it another try.
Some issues:
Will try again. Thanks.
