Most of my objects are
with round corners and
inside and or some drawing or image set as a group, and often containing again another
with
as a group,.What is missing to me is (it may exist but I didn't find how to do this):
- a(n easy ?) way to put the connectors (
) between shapes (
) where I want (
- some kind of object library, I do use a lot of different
with different
and filters. I often just copy/paste the groups then change the
for another main color or use another filter- having the ability to select a property as a "group property", for example, I would like to be able to change the different foreground colors of my main elements in my groups just by clicking on the group, not by selecting each sub element, one by one (it can be annoying when you have ten levels of groups)
- having an option not to change the border radius for
with round corners when resizing the element or the group containing the element- having an option to anchor my text on a part of another shape/group, like being anchored relatively to the middle of a border, relatively to a corner, or relatively to the middle of the element
- having the ability to set what elements to resize or not when resizing a group
selected, on the tool control bar there is a label on the right named "Affect" followed by a series of buttons. Each of those buttons toggles how effects transform with the object. Turn of the rounded-corner one so they don't resize.
