When I open a pdf, it opens to a small window that cannot be made bigger.
Does PDF file only save what's on the doc, or also save general workspace?
Inkscape opening pdf document to small partial window only
Re: Inkscape opening pdf document to small partial window only
Check the settings panel when saving as pdf... so that save as PDF saves the page size.
(If you look at the PDF document properties (In Adobe reader, Menu:File>Properties), it will show the page size.)
