Importing dxf made in torchmate cad?
tm america
Hi I seem to be having issues importing dxf files created in torchmate card..everytime ivory to open or import them it opens up another inkscape changes the settings and nothing shows up?I tried a control-a and there is nothing to select..Am I missing some setting I need to change?
Re: Importing dxf made in torchmate cad?
Please share a file using link to dropbox or google etc. (upload dxf is not allowed here)
Then we can get a better idea...
Would zipping allow the DXF? I'm not sure, just asking
How are you trying to open/import the DXF? Right-click from file manager, open Inkscape then use Open dialog (File menu > Open), open Inkscape then use File menu > Import, or other way?
Actually, I'm not sure if Inkscape can open a DXF file. Import probably, but I'm not sure how much editing would be possible. This is all the info I have about file formats: https://inkscape.org/en/learn/faq/?edit ... ort/export? and
Oh ok, here we go, from the manual:
(Yikes, I didn't mean to, but looks like I managed to make the whole quote into a link
".dxf (AutoCAD) Imported via internal script. The import is geared for AutoCAD release 13 and newer files (use QCad to update older files). Note that the imported objects may be very small, use 4 to zoom in on them."
