This is not just a display issue - if I scale the shape up by 6400%, the corruption remains.
And some such shapes change their appearance on change of zoom, e.g.
This is on Inkscape 0.48.4 r9939, Win 7 Pro 64-bit.
brynn wrote:It's hard to say what the problem is, just from your screenshots. We don't know what the objects that you've showed us are supposed to look like.
brynn wrote:If it's not a display issue, then the problem must be in the file....unless this is a bug. Would you please provide the SVG file for us? You could attach to a reply
ragstian wrote:At this high zoom the stroke width seems to cause problems.
ragstian wrote:Try setting your stroke width to 0.01 or even 0.001 pixel.
ragstian wrote:Your rectangle in the file provided shows up as a blue rectangle with black stroke and rounded corners at the maximum zoom of 25600%
v1nce wrote:From the source of the svg it's not a pure rect it's a rect with rounded corner.
brynn wrote:It's the same problem as before. The rectangle has round corners.
brynn wrote:When you're working with objects that small, you'll need to use very, very narrow stroke widths.
brynn wrote:So it's not a problem at all.
brynn wrote:If you have a stroke width that's wider than the object, it can't possibly be drawn correctly.
brynn wrote:I don't know if this would be considered a bug or not. Perhaps it is.
brynn wrote:I don't think the part about the zoom causing the problem is correct. ....well, maybe zoom, alone.... The file I attached is at 100% zoom.
Coo... I've no idea how that happened. Thanks for the heads up. I have added the correct link.ragstian wrote:The link you posted is incorrect - it opens brynn's last post for edit.
