textext.py:55: DeprecationWarning: the md5 module is deprecated; use hashlib instead
import os, sys, tempfile, traceback, glob, re, md5, copy
Traceback (most recent call last):
File "textext.py", line 306, in <module>
raise RuntimeError("Neither pygtk nor Tkinter is available!")
RuntimeError: Neither pygtk nor Tkinter is available!
I suppose it is a compatible extension with Inkscape versions prior to 0.91. Could you recommend some other solution?
Thanks in advance
