An algorithm to draw smooth curves I made
benpaulthurston
I thought of this algorithm to allow someone to draw a series of points and the computer would draw a smooth curve through them. It's different than bezier curves or polynomial interpolation and I think better than both. I explained it on my blog, I don't know if I'm going to try and publish a math paper on it or not but I think it's interesting. http://benpaulthurstonblog.blogspot.com/2013/07/constructing-smooth-curve-from-set-of.html
Re: An algorithm to draw smooth curves I made
Interesting method, but what's with the starting and end segments?
Is this algorithm about to draw a "random" curve, between two circle archs?
benpaulthurston
No, I think I explained it better on the next page of the blog along with source code in python...
http://benpaulthurstonblog.blogspot.com/2013/07/smooth-curve-generator-implemented-in.html
also could someone explain how the url thing is supposed to work I can only get it to preview right some of the time...
benpaulthurston
You were right about the endpoints, the first and last affect the curve a little but can be put whereever.
It seems you did get the url right.
Here are the ways you can use them:
Which all gets you to the right direction:
Link to the pagehere.
[url]http://benpaulthurstonblog.blogspot.com/2013/07/smooth-curve-generator-implemented-in.html[/url]
Link to the page[url=http://benpaulthurstonblog.blogspot.com/2013/07/smooth-curve-generator-implemented-in.html]here[/url].
[url=http://benpaulthurstonblog.blogspot.com/2013/07/smooth-curve-generator-implemented-in.html][img]http://2.bp.blogspot.com/-fzApYEaEXms/UeY_PyAftrI/AAAAAAAABfI/oDaeBkEJO3A/s1600/drawsmooth.png[/img][/url]Which all gets you to the right direction:
benpaulthurston
Oh, ok I guess I was thinking it didn't show the url in the preview so I thought I was doing it wrong... Someone also pointed out the red dots in my drawing don't quite match up that's because I was manually drawing the dots, but for example 520,20 is a point given in the program and it is on the curve appropriately not where the red dot for that point would lead you to believe.
