Jacko
Re: Jacko
they make the layer partially transparent (the amount depends on the mode formula i guess) and they change the colors of that layer in a certain way, depending on the colors that are beneath the layer.
You can read in detail here http://gimp-savvy.com/BOOK/ in section 5.6 Blending modes, you can find the examples there. That book is for Gimp, a raster application, Inkscape doesn't have all the modes you can see there. The best way to see what they're about is to try it yourself. Make 2 layers with colorful objects, then change the blend for the top one
you can also search for "layer blend modes", you'll find lots of tutorials
Re: Jacko
the Inkscape Guide has a good explanation specific to Inkscape at http://tavmjong.free.fr/INKSCAPE/MANUAL ... ters-Blend
But as prkos suggested, these blend effects are common to many applications.
