Win8 Bezier path effect
Little_Bear
When trying to use the built in triangle in/out or ellipse path effect on a Bezier curve, the weight cannot be edited after creation. When I look at the path effects editor"power stroke" is listed instead of pattern along path. This is only happening on my Windows 8 machine. I have tried installing the previous release and even the portable version,but the result is the same. Any ideas on what could be causing this?
Re: Win8 Bezier path effect
This may be the case.
The new powerstroke implementation uses handles as far as I know;
the older version's pattern along path lpe could be changed to a different weight by the pattern witdh setting in the lpe tab.
