How to fill an object with bitmap
When I make object for example square or circle and want fill it with bitmap, how can I do it? If I use "fill and stroke" menu so there are filling with pattern only. When I use it, object is filled only with some parts of pattern. Is another methods how to fill an object?
Re: How to fill an object with bitmap
You go to:
1.File>Import you image texture
2.With image selected Object>Pattern>Objects to Pattern
3.Delete the reference image
Now you have your desired image as a reusable pattern.
This video by heathenx should clear it up for you.
Thank you for your advice. But If I used it the object was filled but the bitmap filled it only like some part. After double click on the filled object a tool for rotating and resizing appeared. Is any other possibility how to set a features of the pattern?
and what show ups is what is depicted in
