[solved] Editing PDF
GhostViper
Hello all. Im new to inkscape and i have a question that might be easily fixed. I run a online forum based game. The map we are using is a PDF based map. Is there any way you can edit this via inkscape? I tried to open it but i got a error that Inkscape couldnt open file type.
Re: Editing PDF
Hi GhostViper!
I was just chatting to ScislaC and prokoudine on the #inkscape IRC channel and they informed me that;
At the present time PDF import into Inkscape is not supported, however it is in the pipeline as a google summer of code projectfor inkscape:
But the PDF export from Inkscape can also be a bit flaky, so it may be a while before you can acutally "Edit" a pdf in inkscape...
Nicu (http://nicubunu.ro/) has done some work previously on creating RPG maps in SVG format using inkscape...
LINK: http://clipart.nicubunu.ro/?gallery=rpg_map
Re: Editing PDF
If you like, I might be able to convert the PDF to SVG using Illustrator so you could edit it yourself. Post a link to file if you would like me to try.
Re: Editing PDF
You can try to convert PDF to a SVG using Ghostscript or with pstoedit applications. I usually use the pstoedit tool, the result is not 100% but it is a good start. Some things like embedded images in PDF are not supported by this conversion.
GhostViper
Re: Editing PDF
The map is quite large so you will have to email it back to me. My email is mailto:vol1312@aol.com. Thank you all for the quick replies and all the help.
map
map
Re: Editing PDF
First off, I provide this under the assumption you have the necessary copyright permission to modify it - http://www.microugly.com/temp/3067ccs.svg
Secondly, I would attempt to contact the creator of the map and ask for a copy of the original file. It's always easier to work with the original rather than a coverted copy.
GhostViper
Re: Editing PDF
Thank you very much. I appreciate all of your help. I will be sure to spread the word about the site.
