Can anyone give me any tips for smoothing curves?
I am designing a logo for someone and have traced an image which they provided and all is fine apart from the fact that the curves are a bit harsh. above and below the text there is a kind of long sine wave vector which I need to smooth.
I have played around with the nodes and handles but don't seem to get any better results. Is there some trick I can use?
I have tried selecting the surrounding nodes and clicking the 'make selected nodes smooth' but to no avail.
Thanks for any advice and for an amazing app!
Tips for smoothing curves?
housey
Re: Tips for smoothing curves?
I've added an image so you can see what I mean.
http://img404.imageshack.us/my.php?image=pgslogo5ti9.png
the pen tool is sometimes tricky to master. i would suggest a few things.
1. too many nodes can be cumbersome to blend. try deleting some if you have too many.
2. if you have cornered nodes then convert them to smooth or symmetric nodes
ref: http://screencasters.heathenx.org/wp-co ... ep075.html
3. spiro would work brilliantly for your design. perhaps consider using the devel build for this project.
ref: http://screencasters.heathenx.org/wp-co ... ep067.html
For the snake like shape like the one you have on the bottom I would only use 2 nodes (the ones at the end, they would obviously have to be cusp nodes.)
housey
Thanks for the great advice guys! will let you know how it goes
