Hey there,
as the subject it already is saying, I'm trying to set up some Hot Keys for "Align and Distribute". As an example, let's take "Center on vertical axis". Is it possible to bind that option to a button(Maybe to the button "a")? I already researched it a little bit, but couldn't find anything that helpfull.
I'm using Inkscape on a Windows XP host.
Thanks in advance for every informatione
Your's sincerely
Roman Cvijanovic
Set up Hotkeys for Align and Distribute
Roman Cvijanovic
Re: Set up Hotkeys for Align and Distribute
If you can find Inkscape/share/key/default.xml, it contains instructions for mapping keys. However, I don't think that command is mappable. The ones that are configurable can also be found in Help menu > Keys and Mouse Reference as well.
I could be wrong though.
Roman Cvijanovic
Hey there,
I already thought it could be like that. While I searched the web, I found out that I have the possibility to alter the default.xml. Sadly I couldn't find anything regarding my question. Maybe the dev-team could give us some input regarding this question.
Thanks a lot
Yours sincerely
Roman Cvijanovic
Thanks a lot
Yours sincerely
Roman Cvijanovic
No, you are correct ;)brynn wrote: However, I don't think that command is mappable. The ones that are configurable can also be found in Help menu > Keys and Mouse Reference as well.
There are no verbs defined for the individual align and distribute commands, which could then be mapped to keyboard shortcuts. The feature request in the bug tracker is here: “align by keys like (alt-v) vertical align (alt-h) horizontal align”
Roman Cvijanovic
Hey Suv, thanks a lot for your reply. I'll accpet it as it is. I Hope there will be an update which enables that^^
Thanks a lot
Yours sincerely
Roman Cvijanovic
Thanks a lot
Yours sincerely
Roman Cvijanovic
