Hey,
so I created something that I'm using as a thank you for an event and the website that I'm getting the cards printed from is telling me that I the image quality is too low. It has to be a .jpg so after I export it I have to convert it into a .jpg. How do I export the file as a higher resolution?
Thank you!!!
Saving as a High Res File
Re: Saving as a High Res File
Check the size of the drawing, scale, measures, ect. but you could also check this page of Manual as well.
.png may provide a better image quality but once you get the satisfying quality - converting .png to .jpg should not be a problem.
There's an extension for exporting JPGs directly from Inkscape, without first exporting a PNG.
https://github.com/giacmir/Inkscape-JPE ... -extension
