I need to export to eps file, or .ai, but i guess itd not possilbe to export to .ai right ?
So i tried exporting to .eps but inkscape always crashes, the file is pretty simple, no blur, just like 10 simple shapes.
Does anyone can export .eps without problems ?
Is there a wav to conver .SVG to .AI files ?
Thanx
Inkscape crashes on Vista when exporting .EPS ?
giorgiomartini
Re: Inkscape crashes on Vista when exporting .EPS ?
Try a development build, ps/eps/pdf build is much improved there.
You don't need ai, adobe illustrator will import SVG or PDF just fine; if you need to share with someone who can't read SVG, export to PDF.
