Hey folks!
I created a lot of squares (about 100). Now I would like to adapt things like - opacity, filling, outlines, round corners - for all these squares simultaneously.
Especially when I want to adapt someting afterwards, it would need a lot of time to adjust it one by one.
Sorry my english is not that good I now, but I hope you could understand my problem...
Thanks a lot!
[solved] Adapt attributes for several squares simultaneously
Re: Adapt attributes for several squares simultaneously
Copy an object with all the visual styles applied to it, then select all your squares and paste the style (Ctrl + Shift + V).
dannyking-lazy
Also, you should look into the clone tool. It lets you create multiple (or just one) copies of an object and any changes on the original object also happen to the clones.
vektor
Thank you for the answers!
I think the clone tool ist exactly the one I looked for...
