When I try to set up an axonometric grid, it seems like the Y-axis is fixed in vertical orientation and only the angle of the X-axis and the
Z-axis can be specified (in the screenshot below they are both at 30 degrees).
For my purposes it would be more convenient if the X-axis was fixed in horizontal orientation and I would be able to specify the
angle of the Y-axis and the Z-axis (both at 30 degrees).
https://i.imgur.com/ZqSbYdb.png
Is there any way to do this in InkScape?
greetings and thanks in advance for any suggestions, Niek
hexagonal (axonometric) grid in horizontal rather than vertical orientation
Re: hexagonal (axonometric) grid in horizontal rather than vertical orientation
tylerdurden wrote:I'd use the grid generator in the Extensions>Render menu.
viewtopic.php?f=5&t=34354&p=107352&hilit=axonometric+grid#p107352
Ah thanks. That offers more flexibility than using the grid settings in the document properties.
