This seems related to bug #299362 here: https://bugs.launchpad.net/inkscape/+bug/299362 which I know I made a huge mess of it. So I don't dare add anything to it, for fear of making it worse
It seems related, in that the results of the interpolation are spread out some distance from the originals. And I don't mean that the interpolation was performed properly, except that it's far away (that happens too, but I don't mind moving it back, as long as it worked properly) (which happens with most if not all extensions for me). I mean that the interpolated lines touch one another when it works correctly, while in this case, they're 5 to 10 times the distance away from each other. In bug #299362, the same thing happened with radially tiled clones, simply drawing single dots (Pencil tool and Ctrl + click), applying a radial gradient to a group of ellipses, and clipping -- in all cases, some kind of transformation had been used, including Fit Page to Selection, and in all cases, whatever I was drawing was displaced on the canvas (seemed to disappear, but I later found them far away from where I was working). It was reported in Inkscape 0.46 on Windows XP sp3.
The part that seems not related, is that this bug in the past affected the entire document, so that if I duplicated the steps in the same document, the same problem recurred. But they didn't happen in a fresh, new doc. In this case, I duplicated the steps in the same document, and it works properly. (It does also work properly in a new document, btw) While I have not used Fit Page to Selection, I have used some transformations -- rotate and flip. This is in Inkscape 0.48 on Windows 7, 64-bit.
Questions - 1) Is it a bug? 2) Is it related to #299362? 3) Should I add a comment to #299362 or start a new report?
So here is the file. Sorry for the small size, I'm working on animating my avatar. Don't want to scale, since transforms may be part of the problem. 800% zoom should work well, and hopefully it will open already zoomed.
Thank you very much
