Hey guys,
I seem to have done something to my Inkscape. Whenever I draw an ellipse, it shows a line from the center of the circle to the outer edge (the radius). I just want a plain circle - how do I remove that line?
Kind Regards,
William.
Remove the Radius Line from a circle
- shawnhcorey
Re: Remove the Radius Line from a circle
The circle is in segment mode. To change it to a full circle, click on the object and select the circle tool. In the tool's toolbar, click on the full circle (the one on the end).
williamz902
Perfect, thank you so much... I found it and sorted it out using your instructions! thank you a million.
