Deleting transform changes d value.
but it appears that transform of all upper nodes also influences d value.
How to get rid of all transform values all nodes up ?
if you select(select & transform selector) "<svg:path" you can then move a bit that path & move it back and transform is deleted.
Does not work that way on upper nodes thta are not "<svg:path" type.
Basicaly I want to keep everything where it is having all transform values deleted.
Delete transform ? d value
BubikolRamios
Re: Delete transform ? d value
It appears you get clean d value by edit/cut , edit/paste path & drag path back to where it was.
Nice if you have some paths around to know exactly where to put it back.
Not good in other cases.
